Jul 20th, 2024, 11:28pm
any passive r-c circuit which can filter CM noise in band. (Read 5222 times)
yvkrishna
Oct 29th, 2014, 2:38am
I have a Diff signal and CM noise in band, is there any passive circuit which can filter the CM noise component without filtering the DM signal component.
yvkrishna
Re: any passive r-c circuit which can filter CM noise in band.
Reply #1 - Nov 2nd, 2014, 7:12pm
Process the signal though a differential amplifier that should have significant CMRR characteristics.
Keep the system fully differential end to end in any and all analog parts
yvkrishna
Reply #2 - Nov 2nd, 2014, 8:38pm
@loose-electron,
differential amplifier is probably the best way to address this, however my CM noise swing is about 4X larger the min. detectable DM signal present.
However I wonder if there exists any passive circuit which can do this job?
When I search for this on google I only get Commonmode choke.
I have also tried using a T network (shown in the pic)which offer different impedance for CM and DM picture, even here I am not able to achieve CM bandwidth < DM bandwidth.
looks like there is some fundamental limitation in what I am trying to achieve using passives.
yvkrishna
Reply #3 - Nov 3rd, 2014, 4:59pm
consider a common mode choke then. External to the chip if needed, or even internal to the chip if you have the freedom of doing some electromagnetics inside the chip. Will depend heavily on frequency range needed and the consequent size of the device.
yvkrishna
Reply #4 - Nov 3rd, 2014, 10:02pm
I doubt if there exists any simple r-c circuit which does this.
Or is this impossible without using electromagnetics ?
Reply #5 - Nov 6th, 2014, 4:01pm
plenty of active circuit methods
does it have to be passive? If so I think you are going to need some electromagnetics
hiSkill_11
Reply #6 - Sep 8th, 2015, 11:57pm
How about using diff amp with high DM BW and low CM BW?
yvkrishna wrote on Oct 29th, 2014, 2:38am:
yvkrishna
Reply #7 - Sep 10th, 2015, 10:22am
Have you researched the concept of "Instrumentation Amplifiers" ???
Getting rid of big common mode signal content is what these are designed for.
Research time.
