Jul 18th, 2024, 12:25am
how to delay a signal (Read 2850 times)
jagadeesh
Oct 29th, 2014, 7:52am
how to delay a signal dynamically...suppose some integer is there and depending on its value..i have to delay input signal...
Re: how to delay a signal
Reply #1 - Nov 13th, 2014, 10:18am
Have you looked at absdelay()?  It allows a variable delay, as long as you specify the third argument, which is the maximum delay.
Reply #2 - Nov 14th, 2014, 5:21am
If the value you want to delay over time is piecewise constant, you should use the transition function to delay it. It is a much lighter function than $absdelay and has better error control. If the value varies continuously with time, then Geoffrey's suggestion of $absdelay() is best.
