May 12th, 2024, 10:00pm
Pages: 1 2
stb phase margin (Read 18584 times)
newic
stb phase margin
Dec 12th, 2014, 5:57am
Hi
I use spectre stb analysis with the same setup as in
http://www.lumerink.com/courses/ece5411/Handouts/Loop%20Stability%20Analysis.pdf...
The phase will start at +180o degree right. As long as the phase is >0 degree below unity gain freq (ugf), the design is consider stable right.
What if the phase starts at 0 degree? will it consider stable? The stb still reported +ve phase margin. Is stb reported phase margin reliable?
raja.cedt
Re: stb phase margin
Reply #1 - Dec 12th, 2014, 6:02am
check your circuit, some where you might have wrongly connected such that it will be +ve feedback.
Check your dc operating point once before you start stb.
Raj.
Reply #2 - Dec 12th, 2014, 9:13am
Remember that the Spectre stability analysis is reporting the loop
gain. If the phase starts at 0 degrees then it is likely that either
the inputs are reversed or the circuit is not biased properly.
If the phase is 0 degrees at zero then the circuit has positive feedback.
If the gain is low then the circuit may behave. That is if the gain is
low, then it won't latch up.
Since phase margin measured at the unity gain frequency, the phase
at dc is not relevant. That even loops with multiple poles and zeroes
can be stable and have positive margin. If the effect of the poles
and zeroes can be neglected at the cross over frequency.
No, if you are using the Bode plot then
1) if the gain is 1, then phase margin needs to be positive,
   typically greater than 45 degrees
2) if the phase is 0, then the gain needs to be less than zero
newic
Reply #3 - Dec 12th, 2014, 11:16pm
Hi Sheldon,
Does it mean that I cannot rely on the stb phase margin report right?
the STB result a +ve phase margin but when i look at the phase response, it starts at 0degree at 1Hz. it should be unstable right.
In most of the corners, it starts at +180o at 1Hz, but in some cases, it starts in 0 degree.
newic
Reply #4 - Dec 12th, 2014, 11:18pm
hi Raj,
the DC value is correct. i have confirmed that
buddypoor
Bremen, Germany
Reply #5 - Dec 13th, 2014, 2:15am
newic wrote on Dec 12th, 2014, 11:16pm:
Hi Sheldon,
Let me state the following:
1.) For stable feedback circuits the phase of the loop gain always must start at -180deg . This is necessary for negative dc feedback (stable operational point).
2.) In this case, the gain margin is to be determined at a frequency where the loop phase reaches -360deg (0 deg).
3.) Sometimes, not the loop gain is analyzed but the product of all units within the loop only (without the minus sign at the summing node).
This product is, of course, identical to the negative of the loop gain. In this case, the phase starts at 0 deg and stability is checked at the -180deg point.
newic
Reply #6 - Dec 14th, 2014, 5:28pm
hi buddypoor
based on the setup in http://www.lumerink.com/courses/ece5411/Handouts/Loop%20Stability%20Analysis.pdf....
where the ac source /iprobe  at the feedback path.
the phase should start at +180o from stb plot right. as long as the phase > 0o before UGF. it is stable.
Frank Wiedmann
Munich, Germany
Reply #7 - Dec 16th, 2014, 12:58am
buddypoor
Bremen, Germany
Reply #8 - Dec 16th, 2014, 3:55am
newic wrote on Dec 14th, 2014, 5:28pm:
hi buddypoor
I think both cases are identical:
* Phase from +180deg to zero deg;
* Phase from -180deg to -360deg.
By the way: I couldn`t open the given link.
newic
Reply #9 - Dec 16th, 2014, 7:28pm
the link is broken due to the "." in the end of the link
pls use the
newic
Reply #10 - Dec 16th, 2014, 7:31pm
To add on, my circuit has 2 loops: main loop and a fast loop.
most of the corners start at 180o but in few cases, it starts at 0o.
Can STB analyse 2 loops correctly? as i only break in the main loop (feedback path).
buddypoor
Bremen, Germany
Reply #11 - Dec 17th, 2014, 3:30am
newic wrote on Dec 16th, 2014, 7:31pm:
More than that, how to proceed if no main loop can be identified because there are two nested loops?
(I think, STB analysis requires that both loops are to be opened at the same time)
newic
Reply #12 - Dec 17th, 2014, 7:09pm
Hi buddypoor
"(I think, STB analysis requires that both loops are to be opened at the same time) "
how to achieve that in STB if having 2 loops?
In the STB setup, only one probe is allowed.
buddypoor
Bremen, Germany
Reply #13 - Dec 18th, 2014, 12:53am
newic wrote on Dec 17th, 2014, 7:09pm:
Yes - and that is the problem (in some cases) because we have to decide which of the loops is dominating and mainly determines the circuits behaviour? Up to now - I didn`t find any answer to this general question.
raja.cedt
Reply #14 - Dec 18th, 2014, 2:24am
Hi Newic,
When you have several loops you should find a common point where you can break all the loop. For example band gap, opamp o/p is prefect point to keep stb-probe.
I also don't know how to proceed if I can't find a common break point.
Raj.
Pages: 1 2
