jovial
hello all!!!
i am using this code for sigma delta adc in veriloga . But the SNR of the output is low. can anyone check and suggest me the modifications.
// VerilogA for decimation, sdm, veriloga
`include "constants.vams" `include "disciplines.vams"
module sdm(in,clk,out);
input in,clk; output out; voltage in,clk,out;
parameter real clk_vth=0.9; parameter alpha = 0.5; parameter beta = 0.5;
real int1_out; /// variable-- not connection with the outside world real int2_out; real dac_out; real mix1_out; real mix2_out; real t_int1_out; real t_int2_out; real sdm_out;
analog begin @(initial_step) begin
int1_out = 0.0 ; int2_out = 0.0 ; dac_out = 0.0 ; mix1_out = 0.0 ; mix2_out = 0.0 ; sdm_out = 0 ; t_int2_out = 0 ; t_int1_out = 0 ; end
@(cross(V(clk) - clk_vth,1)) begin mix2_out = int1_out - dac_out ; int2_out = t_int2_out + beta*mix2_out ; t_int2_out = int2_out ; mix1_out = V(in) - dac_out ; int1_out = t_int1_out + alpha*mix1_out ; t_int1_out = int1_out ; if (int2_out >= 0.0) sdm_out = 1.8 ; // ADC-- comparator else sdm_out = 0 ; if (sdm_out == 0) dac_out = 0.5 ; else dac_out = 1.3 ; end V(out) <+ sdm_out ; end endmodule
