May 5th, 2024, 1:22pm
sigma delta adc code in veriloga (Read 3856 times)
jovial
Dec 21st, 2014, 8:58am
hello all!!!
i am using this code for sigma delta adc in veriloga . But the SNR of the output is low. can anyone check and suggest me the modifications.
// VerilogA for decimation, sdm, veriloga
`include "constants.vams"
`include "disciplines.vams"
module sdm(in,clk,out);
input in,clk;
output out;
voltage in,clk,out;
parameter real clk_vth=0.9;
parameter alpha = 0.5;
parameter beta  = 0.5;
real int1_out;   /// variable-- not connection with the outside world
real int2_out;
real dac_out;
real mix1_out;
real mix2_out;
real t_int1_out;
real t_int2_out;
real sdm_out;
analog
begin
 @(initial_step)
 begin
   int1_out = 0.0 ;
   int2_out = 0.0 ;
   dac_out  = 0.0 ;
   mix1_out = 0.0 ;
   mix2_out = 0.0 ;
   sdm_out  = 0 ;
   t_int2_out  = 0 ;
   t_int1_out  = 0 ;
 @(cross(V(clk) - clk_vth,1))
 begin
  mix2_out   = int1_out - dac_out ;
  int2_out = t_int2_out + beta*mix2_out ;
  t_int2_out = int2_out ;
  mix1_out   = V(in)    - dac_out ;
  int1_out = t_int1_out + alpha*mix1_out ;
  t_int1_out = int1_out ;
    if (int2_out >= 0.0) sdm_out = 1.8 ;   // ADC-- comparator
    else                 sdm_out = 0 ;
  if (sdm_out == 0)    dac_out = 0.5 ;
  else                 dac_out =  1.3 ;
 V(out) <+ sdm_out ;
Novaris
Re: sigma delta adc code in veriloga
Reply #1 - Dec 21st, 2014, 12:27pm
The code itself seems to be ok but what makes me wonder are your DAC values. I asume that your common mode or agnd in the circuit is 0.9V as you use the same in your cross detection as threshold. Typically all integrators should start also at agnd. Also your dac values then make more sense (0.9 +- 0.4).
What type of test signal are you applying?
BR
Novaris
ruwan2
Reply #2 - Mar 27th, 2015, 7:23pm
sigma-delta ADC's high SNR comes from a noise shaping filter. I do not see it in your design yet.
