Jul 17th, 2024, 9:26pm
Bury layer in BCD process? (Read 4062 times)
Jan 14th, 2015, 7:44am
Hi Guys,
I heard that all BCD process has bury layer? What's the use of the bury layer?
Best regards,
Yawei
Re: Bury layer in BCD process?
Reply #1 - Feb 9th, 2015, 3:52pm
Y,
 More info would be good. If it is the N+ buried layer underneath the
npn transistor, then it serves several functions:
1) Lower collector resistance of the npn, lower collector resistance
   means lower saturation voltage.
2) It suppresses the beta of the parasitic vertical pnp formed by
   the p-base, E, n-collector, B, and p-wafer, C. The idea is that
   if the base is more highly doped than the emitter, then Beta
   will be low suppressing latch-up and minimizing current
   injection into the substrate during saturation.
3) N buried layer also prevents the base depletion region from
   reaching the substrate, punchthrough, at high Vcb.
Now if you meant the buried layer under a vertical PNP, that is,
a different thing Smiley
Reply #2 - Feb 19th, 2015, 7:05pm
Sheldon,
Thank you very much.
I am not familiar with Bipolar process or BCD process. I have never thought of the parasitic vertical pnp and latch-up related to the npn transistors.
Would you please recommend any literature about BCD process, including the effects of parasitic devices on circuit design? Thanks.
Yawei
