Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 28
th
, 2024, 1:19pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› Differential noise at the input of Differential Amplifier
Previous topic
Next topic
Differential noise at the input of Differential Amplifier (Read 1763 times)
adie_N
UiTM Malaysia
Jan 14
th
, 2015, 11:29pm
Hai! Good day everyone.
I am freshman of analog design and currently develop the interfacing circuit for electrochemical sensor. In my design, it produces a dual output signal (VOA & VOB) from a single input. Currently I am investigate the noise performance by applying the transient noise at the input of my design and differentiate between the outputs. the simple method to differentiate both of output signal included noise is use the differential amplifier since the diff_amp has ability to reject any common mode noise.
Unfortunately the output of diff_amp become a noisy(VOC). I notice that, it is because the inputs of diff_amp has different amplitude noise (see attachment). I am not sure whether my way to analysis the noise performance is correct or not? is it possible, the different mode noise exists between the input of diff_amp? if Yes, is there any method to reject these noises without using a filter?
Thanks a lot
Best regard
adie
HASLIADI
IP Logged
Re: Differential noise at the input of Differential Amplifier
Reply #1 -
Jan 19
th
, 2015, 1:19pm
OK, is the horizontal scale in the milli seconds or Mega seconds?
Either way you need to limit the bandwidth of your system to that only of the signal of interest.
After that, if it is extremely slow signal I would suggest ADC followed by digital averaging to reduce BW further and average out the noise.
Also, the noise can be further lowered by reducing the impedance of these sytems to reduce the thermal noise.
Other techniques are possible as well.
http://electronicdesign.com/analog/noise-reduction-crucial-mixed-signal-asic-des...
the above are useful as well if it is an interference noise question.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
