Jul 16th, 2024, 2:38pm
LC-VCO design (Read 6962 times)
AZADBAKHT
LC-VCO design
Jan 20th, 2015, 11:36am
I designed a LC-VCO for tuning range of 4.8 to 5.8 GHz.
when i do sweep PSS & PNoise analysis for give best Phase Noise, when I-Tail is teriod region(M4 in picture), Phase Noise of VCO is the best more then Saturation region.e
can anyone tell me why?
Best of Regards,
Azadbakht.
View Profile milad12333   IP Logged
raja.cedt
Re: LC-VCO design
Reply #1 - Jan 21st, 2015, 3:36am
Hi..
generally tail current noise will be up converted and appears mostly in -30db/dec region. Amount of up conversion depends on tail current source gm* tank resistance. Triode current source will have less gm this could be the reason why you are getting low noise. Some low phase noise vco will not have any tail current or they will use some resister to minimize the contribution, but this comes at the cost of supply sensitivity. Please refer the following pap
A Filtering Technique to Lower LC Oscillator
Phase Noise
AZADBAKHT
Re: LC-VCO design
Reply #2 - Jan 21st, 2015, 9:17am
tnx a lot sir raja.cedt for reply my question.
i have any question of you!
in your opinion if M4 is teriod region, not problem for layout and fabricate this circuit? or i must design I-Tail in saturation region?
raja.cedt
Re: LC-VCO design
Reply #3 - Jan 21st, 2015, 1:22pm
that's fine as long as your models are correct. If you you have a stable vdd better go with a resister...
totowo
SH, PRC
Re: LC-VCO design
Reply #4 - Jan 21st, 2015, 6:46pm
I guess it's because you increase the bias current so as to push the tail in triode....
Generally, more power,  less noise.
So you should compare the results with the same power consumption.
AZADBAKHT wrote on Jan 20th, 2015, 11:36am:
Best of Regards,
Azadbakht.
View Profile totowo totowo   IP Logged
AZADBAKHT
Re: LC-VCO design
Reply #5 - Jan 21st, 2015, 10:09pm
Hi raja.cedt,
tnx a lot dear, i got it.
AZADBAKHT
Re: LC-VCO design
Reply #6 - Jan 21st, 2015, 10:18pm
Hi totowo,
Ok, thank you for your attention.
raja.cedt
Re: LC-VCO design
Reply #7 - Jan 22nd, 2015, 8:14am
Phase noise improves with power consumption provided oscillator works in current limited region, as soon as it enters into voltage limited range phase noise will not change with power consumption any more.
Tail transistor enter into triode region if  it is small in size, then it could easily enter during the peaks of the signal swing
Raj.
AZADBAKHT
Re: LC-VCO design
Reply #8 - Jan 22nd, 2015, 11:16am
Hi dear Raja,
Ok, i got it...
tnx a lot for your attention dear.
