Jul 18th, 2024, 12:34am
Verilog-AMS Aysnchronous reset of ring-oscillator phase (Read 3976 times)
sal
Feb 03rd, 2015, 1:42pm
I'm fairly new to Verilog-AMS and trying to model a gated ring-oscillator. I'd like to be able to freeze, reset and then re-enable the oscillator with the reset phase using input signals. I generate the phase using
phase = 2*`M_PI*idtmod(freq*fv,0.0,1.0,-0.5);
and my oscillator output is
V(OUT) <+ offset + ampl*sin(phase);
where frequency is my output frequency and fv is a variable I set depending on the crossing of enable. Once the enable signal goes low, fv becomes 0 and the state of the ring-oscillator is frozen. When enable goes high, the phase continues to integrate.
I have tried to apply a reset of the phase by detecting the crossing of my reset signal but since idtmod is outside of this, the phase of the oscillator always returns to the phase it was at before I froze its state - rather than continue from the reset state.
I'd much appreciate advice on the following - Whether it is possible to reset the phase of idtmod? And if not, is there another way to model a ring-oscillator with this function using verilog-ams?
Re: Verilog-AMS Aysnchronous reset of ring-oscillator phase
Reply #1 - Feb 3rd, 2015, 1:51pm
Perhaps consider a discrete event implementation using disable. Take a look at the synchronouse oscillator found at http://verilogams.com/refman/modules/discrete-procedural/misc.html for inspiration.
boe
Reply #2 - Feb 5th, 2015, 3:44am
sal wrote on Feb 3rd, 2015, 1:42pm:
If you cannot use Ken's suggestion for your application and you need an analog oscillation, I'd suggest to add a phase offset, which changes on reset, e.g. Code:
V(OUT) <+ offset + ampl*sin(phase - phase_offset);
- B O E
sal
Reply #3 - Feb 6th, 2015, 1:42am
Thanks, I managed to get the behavior I wanted by calculating a phase offset using @cross and then subtracting this from the current phase of the oscillator.
