Aug 27th, 2024, 11:20pm
2 pole low frequency shelving filter design (Read 2515 times)
Northy
Feb 07th, 2015, 7:11am
I'm trying to design a 2 pole low frequency shelving filter to boost the low frequencies in an audio circuit.
I've modeled this circuit and it models correctly, but I want to run it on a single supply op amp (LM324).
Should I connect R15 and R16 to 1/2 the supply voltage to make it work correctly?
Northy
Rakesh
Re: 2 pole low frequency shelving filter design
Reply #1 - Feb 7th, 2015, 3:56pm
   Check the output common mode voltage. Connect the resistors to that value. yes typically you need to connect the resistors to vdd/2.
Rakesh
Northy
Reply #2 - Feb 9th, 2015, 12:17pm
This is the circuit that I'm playing with at the moment. It seems to work if I feed about 0.5V into V_Bias. I'm confused why it is only 0.5V though.
Northy
