I am trying to run the simple example as depicted in the image below. But, I am
not able to implement the resistor (
with some user defined parameters rsh and kf) as required here!
![Sad Sad](https://designers-guide.org/forum/Templates/Forum/default/sad.gif)
For that, I tried to take a "res" from analogLib, and then change its "model name" to say "flickres_jdp" and also made a model file (say flickres_jdp.scs) - then added this model file from ADE->Setup->Model Path
The text put in this model file is:
Quote:.model flickres_jdp resistor rsh=1K kf=10e-13
Getting following error:
Quote:ERROR (SPECTRE-16384): Signal V(vout) = -2.45831 GV exceeds the blowup limit for the quantity `V' which is (1 GV)....
Analysis `tran' was terminated prematurely
My questions:
1. Is the above method okay, and is the format of the model file right?
2. Is there any option to include a ".model" statement in the schematic editor in cadence?
3. Is there any way to edit the netlist and then run the simulation?
These might be very trivial..but please help...
