Jul 27th, 2024, 9:22am
User defined resistor model in Cadence Spectre (Read 2629 times)
jdp
Feb 10th, 2015, 9:20am
I am trying to run the simple example as depicted in the image below. But, I am not able to implement the resistor (with some user defined parameters rsh and kf) as required here!   Sad
For that, I tried to take a "res" from analogLib, and then change its "model name" to say "flickres_jdp" and also made a model file (say flickres_jdp.scs) - then added this model file from ADE->Setup->Model Path
The text put in this model file is:
Quote:
.model flickres_jdp resistor rsh=1K kf=10e-13
Getting following error:
Quote:
ERROR (SPECTRE-16384): Signal V(vout) = -2.45831 GV exceeds the blowup limit for the quantity `V' which is (1 GV)....
Analysis `tran' was terminated prematurely
My questions:
1. Is the above method okay, and is the format of the model file right?
2. Is there any option to include a ".model" statement in the schematic editor in cadence?
3. Is there any way to edit the netlist and then run the simulation?
These might be very trivial..but please help... Undecided
-- jdp
Re: User defined resistor model in Cadence Spectre
Reply #1 - Mar 13th, 2015, 11:03am
.model is not Spectre format.  Did you get any warnings at the start of the simulation?
