Jul 16th, 2024, 1:49pm
Load-pull Analysis for Power Amplifiers (Read 1432 times)
Hammad33
Feb 14th, 2015, 3:31am
Hello, I'm a trainee RF engineer. I'm confused as to why we need to use load-pull analysis for finding optimum load impedance. Why don't we just use conjugate match at the output of a PA? And do we need to perform a similar analysis at the source or can we just use conjugate match at the source? Thanks Smiley
rfidea
Europe
Re: Load-pull Analysis for Power Amplifiers
Reply #1 - Feb 14th, 2015, 2:16pm
If you conjugate match the output you will get maximum gain. Usually in a PA you would like to get maximum output power, which says that you would like to find the load where you have the highest output power compression point. Those two point are not the same.
Hammad33
Reply #2 - Feb 14th, 2015, 8:11pm
hmm...Do we need to find an optimum source impedance as well for highest output power compression point ?
RFICDUDE
Reply #3 - Feb 15th, 2015, 5:29am
Yes, the optimum "load" impedance for highest output power compression is generally not a conjugate match.
Steve Cripps has a IEEE MTTS conference paper that does a nice job of explaining matching a transistor output for maximum saturated output power.
Cripps, S.C., "A Theory for the Prediction of GaAs FET Load-Pull Power Contours," Microwave Symposium Digest, 1983 IEEE MTT-S International , vol., no., pp.221,223, May 31 1983-June 3 1983
http://ieeexplore.ieee.org/stamp/stamp.jsp?tp=&arnumber=1130864&isnumber=250...
Hammad33
Reply #4 - Feb 15th, 2015, 9:40pm
Thank you for your help guys!  :)
weber8722
Reply #5 - Apr 21st, 2015, 11:29pm
of course you can use a load-pull analysis and find e.g. the optimum impedances for max. gain, max. pout or best PAE or linearity - they all will be different! So a compromize is needed.
However, I would say this is a good starting point only. Usually at some point an optimizer working on all specs is the best approach! In RF design chaging e.g. a W of the output transistor or the bias point (and bias impedance!) can change all measures simultanously. A human can work well on few parameters and specs only - a good optimizer on quite many!
Bye Stephan
