Aug 15th, 2024, 2:12am
Conjugate Matching in presence of Complex Zo (Read 2287 times)
Hammad33
Feb 18th, 2015, 10:01am
Consider a source with impedance (complex) Zs, then a transmission line with characteristic impedance (complex) Zo and the a load (complex) Zl.
How can we achieve a conjugate match between source and load for max. power transfer in this case?
P.S the case with real characteristic impedance Zo is relatively simple known to me.
weber8722
Re: Conjugate Matching in presence of Complex Zo
Reply #1 - Feb 27th, 2015, 10:17am
where a complex impedance is coming from does NOT matter! Apply the usual conj complex impedance to get power match, that's it.
Maybe best think that you can create a TRL eqivalent circuit, so it obviously does not matter which element comes physically from what (like being part of the line or maybe being an smd component).
One difference is that for real line power match and flat frequency response, having no reflections fit together.
But in general conj matching can be done only for narrow bands.
Bye Stephan
