Aug 27th, 2024, 7:27am
sink and source current source from far gnd (Read 740 times)
newic
Mar 04th, 2015, 1:28am
Hi
Is there any difference to sink or source Iref curent from a current generator (which has good ground) to a  blockA which is far far away?
assume both current generator and blockA has the same VDD.
aaron_do
Re: sink and source current source from far gnd
Reply #1 - Mar 13th, 2015, 1:17am
just remember that current always flows in a loop. You should be able to model what would happen by including some ground impedance.
If the generator is referenced to the ground at the source, then you are likely to have some "ground bounce" at the load. The current itself will not change unless it is dependent on the load impedance.
regards,
Aaron
newic
Reply #2 - Mar 18th, 2015, 10:21pm
thank you!
