Dshoter
Hi. I'm trying to design a CMOS Class B PA using Virtuoso. I designed my output matching network for maximum gain.. but when I'm simulating S-Param, Harmonic Balance and doing Periodic States Simulations etc, I have to use a Port, and It comes with 50Ohm resistence. My question is: it will have impact in my PA performance? Do I have to design a input matching network to obtain the correct results in Virtuoso?
Thank you all for you attention.
Best regards.
