Jul 16th, 2024, 11:18am
RF CMOS Power Amplifier Design - Virtuoso (Read 2824 times)
Dshoter
Mar 11th, 2015, 10:31am
Hi. I'm trying to design a CMOS Class B PA using Virtuoso. I designed my output matching network for maximum gain.. but when I'm simulating S-Param, Harmonic Balance and doing Periodic States Simulations etc, I have to use a Port, and It comes with 50Ohm resistence. My question is: it will have impact in my PA performance? Do I have to design a input matching network to obtain the correct results in Virtuoso?
Thank you all for you attention.
Best regards.
Dshoter
Re: RF CMOS Power Amplifier Design - Virtuoso
Reply #1 - Mar 11th, 2015, 12:05pm
Problem Solved, thank you anyway Smiley
With best regards.
AdamAzzata
Reply #2 - Sep 25th, 2015, 4:54am
For simulation you do not need to design any impedance matching circuits for input and output. But if you add then the results will be better. For practical circuits you must add them. They are necessary for the proper functioning of your circuit.
