Jul 20th, 2024, 5:16pm
What is the application of this buffer? (Read 1702 times)
Jacki
Mar 16th, 2015, 6:36am
   I see this buffer in an integrator-oscillator, and I am a little confused about this buffer. Can anyone explain what this buffer does in the circuits? Normally this kind of connection in an OTA will give a negative grounded resistor.
   Because "Vi=Vo" (the same in the simulation), it works as a unity gain buffer. Why don't we use the voltage follower connection (Vi is at the positive input, and the Vo connects to the negative input)?
   Somebody told me that "Vi=-Vo", and this buffer works as a block of "-1", but I cannot understand how to calculate the results based on the node current theory.
   Thank you.
   Jacki
Jacki
Re: What is the application of this buffer?
Reply #1 - Mar 16th, 2015, 8:50am
By the way, how to realize an unity gain inverter (not use the resistive feedback)?
Thank you.
Jacki
Reply #2 - Mar 16th, 2015, 9:01pm
It is a unity gain buffer where the input is mismarked. The input is the plus input of the opamp, and it is connected to ground. By the virtual short circuit principle, the output will also be at ground. The buffer prevents the output from loading the input, meaning that in this case the ground symbol may represent a high-impedance path to ground.
Reply #3 - Mar 17th, 2015, 10:44am
www.ti.com/ww/en/bobpease/assets/AN-31.pdf
30 pages of op amp circuits
Jacki
Reply #4 - Mar 18th, 2015, 7:09am
Hello Ken and Loose-electron,
   Thank you very much for your reply and attached document. I will study it, and find if the buffer is connected in a wrong way in that oscillator.
   -Jacki
hiSkill_11
Reply #5 - Sep 6th, 2015, 7:03pm
It seems to be 1/gm resistor.
Jacki wrote on Mar 18th, 2015, 7:09am:
   -Jacki
A Kumar R
India
Reply #6 - Sep 12th, 2015, 10:52pm
Hi Jacki,
Yes, as Ken said it seems to be a mistake of the connection. Vo = Vi in this circuit also but there is no use of the amp there bcoz there is a direct path from the input to output.
Bye
Anil
raja.cedt
Reply #7 - Sep 15th, 2015, 4:10pm
@Jacki: This is a very standard load in gm-C filters, just open any of the gmc filter you will see this. I haven't designed any gm-C filters, but time constant tuning(C/gm) would be easy if we implement resister like this and of course area as well.
Raj.
A Kumar R
India
Reply #8 - Sep 15th, 2015, 10:28pm
Hi Raja,
Can you please clarify how this structure can act as a resistor?. What i could see is that there is just a short between i/p and o/p and the op-amp is of no use here. It always sees the difference when a signal is present and it can't correct it.
Bye
