Aug 14th, 2024, 11:23am
pre and post cursor information from S21 (Read 3246 times)
raja.cedt
Mar 18th, 2015, 11:19am
dear all,
How to estimate relative strengths of significant pre an post cursors with Channel S21. For exact numbers I have to do IFFT of the transfer function but if there is any simple method, then we could easy tell the impact of high peaking CTLE on the ISI or impact of the mid-band rise/gain of the ctle.
or can any one explain slide 30,31,34 in the following material, so author got that information with each modification in overall response?
https://www.pcisig.com/developers/main/training_materials/get_document?doc_id=cf...
Raj.
bharat
Re: pre and post cursor information from S21
Reply #1 - Jan 15th, 2016, 6:05am
Raj,
The given link is not working. Can you update the link, if you have the document.
As I don't have access to the said doc and its slide nos. but Impulse response will always be more informative than s21 response of the channel.
Unless one doesn't have gain and phase plot of AC response of the channel, its difficult to predict pre/posr cursor but it becomes easier on looking the impulse response.
-Bharat
