Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 26
th
, 2024, 11:16am
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› ESD protection for multi-supply
Previous topic
Next topic
ESD protection for multi-supply (Read 5649 times)
newic
Mar 18
th
, 2015, 11:38pm
Hi
How is the ESD protection scheme for multi-supply system? I am more concerns on ESD event from VDD1 to VDD2, assume VDD2 is a reference during ESD event.
I read some books that recommends to add bidirectional diode between 2 supplies. But it will cause leakage during power up event. is it a practical solution?
Is there any good solution?
IP Logged
newic
Re: ESD protection for multi-supply
Reply #1 -
Apr 14
th
, 2015, 7:41pm
any expert can comment??
IP Logged
RobG
Bozeman, MT
Reply #2 -
Apr 15
th
, 2015, 2:49am
I'm not even close to an expert, but the Vdd pads I see these days have a snapback device between the pad and ground. This protects each Vdd pad
relative to ground
so there is no need to put diodes between the separate Vdds.
IP Logged
newic
Reply #3 -
Apr 16
th
, 2015, 12:54am
hi
It is true that each supplies has a clamp between vdd1/2 to vss.
But the clamp will not turn on if Vdd1 & Vdd2 did not have a common ground. The charge can go from vdd1 to vdd2 through the level shifter circuit instead of going through vss. assume Vdd1 pairs with vss1 while vdd2 pairs with vss2.
IP Logged
RobG
Bozeman, MT
Reply #4 -
Apr 16
th
, 2015, 1:53am
I guess you would have your snapbacks between the vdd pads and a common line, such as substrate or one of the vss lines. Then put back-to-back diodes between the vss pads.
IP Logged
newic
Reply #5 -
Apr 16
th
, 2015, 10:13pm
Hi RobG,
it is not a snapback ESD device at the power supplies.
CMOS RC-Triggered MOSFET ESD Power Clamp is used instead.
Is there a problem?
IP Logged
RobG
Bozeman, MT
Reply #6 -
Apr 17
th
, 2015, 7:08am
Yes, same idea. I see my Vdd pads use the RC clamps.
IP Logged
newic
Reply #7 -
Apr 22
nd
, 2015, 1:13am
thx!!
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
