Jul 16th, 2024, 11:44am
Differential LNA (Read 2062 times)
repah
Differential LNA
Mar 26th, 2015, 9:12pm
I am designing a differential CMOS LNA with a 60ohm differential source impedance and a 200ohm output impedance.
When I am sizing by devices and doing simulations, what impedance should I use in Cadence's ports ?  Should I design a half of the differential LNA and then add the other half ?  What approach is best ?
Any advice or resources would be helpful.
Thanks!
Re: Differential LNA
Reply #1 - Mar 27th, 2015, 2:55pm
You should use an ideal balun at the input and output to decompose the input and output into separate differential and common-mode components and drive them separately. You said the input source has a 60Ω differential source impedance, so make the port connected to the differential port of the input balun 60Ω. You will also need to connect something to the common-mode port to model the common-mode source impedance. Do the same for the output.
See A test bench for differential circuits for further details.
