I find the below code on line. When I load it as a project to SMASH, I do not see the function of d2a. If d2a is excluded from the project, it can be loaded to the EDA software. I suspect that d2a has rule on net 'b' between buffer and resistor. Is it right?
Do I need to add more code?
Could you explain it to me?
Code:`include "disciplines.vams"
connectrules my_connectrules;
connect d2a;
endconnectrules
Code:`timescale 1ns / 10ps
module testbench ();
electrical gnd;
ground gnd;
reg clk;
initial clk=0;
wire b;
always begin
#10
clk=1;
#10
clk=0;
#10
clk=1'bx;
#10
clk=0;
#10
clk=1'bz;
buffer buf0 (b, clk);
resistor #(.r(100k)) r0 (b, gnd);
module buffer (out, in);
output out;
input in;
assign out = in;
Code:// Logic to Electrical Connect Module
// Version 1a, 1 June 04
// Olaf Zinke
// Downloaded from The Designer's Guide Community (www.designers-guide.org).
// Post any questions on www.designers-guide.org/Forum.
// Taken from "The Designer's Guide to Verilog-AMS" by Kundert & Zinke.
// Chapter 4, Listing 18.
connectmodule d2a (out, in);
parameter real v0 = 0.0; // output voltage for a logic 0 (V)
parameter real v1 = 5.0; // output voltage for a logic 1 (V)
parameter real vx = 2.5; // output voltage for a logic x (V)
parameter real vz = 5.0; // output voltage for a logic z (V)
parameter real r0 = 1k from (0:inf); // output resistance for a logic 0 (Ohms)
parameter real r1 = 1k from (0:inf); // output resistance for a logic 1 (Ohms)
parameter real rx = 100 from (0:inf); // output resistance for a logic x (Ohms)
parameter real rz = 1M from (0:inf); // output resistance for a logic z (Ohms)
parameter real tr=1n from [0:inf); // rise time (s)
parameter real tf=1n from [0:inf); // fall time (s)
input in;
output out;
logic in;
electrical out;
real v, r;
assign in = in;
initial begin
case(in)
1'b0: begin v = v0; r = r0; end
1'b1: begin v = v1; r = r1; end
1'bx: begin v = vx; r = rx; end
1'bz: begin v = vz; r = rz; end
endcase
always @in begin
case(in)
endcase
analog
V(out) <+ transition(v, 0, tr, tf) + transition(r, 0, tr, tf)*I(out);
