May 1st, 2024, 5:45pm
How to use the example project having d2a? (Read 1453 times)
ruwan2
Mar 27th, 2015, 8:49pm
I find the below code on line. When I load it as a project to SMASH, I do not see the function of d2a. If d2a is excluded from the project, it can be loaded to the EDA software. I suspect that d2a has rule on net 'b' between buffer and resistor. Is it right?
Do I need to add more code?
Could you explain it to me?
`include "disciplines.vams"
connectrules my_connectrules;
    connect d2a;
endconnectrules
`timescale 1ns / 10ps
module testbench ();
    electrical gnd;
    ground gnd;
    reg clk;
    initial clk=0;
    wire b;
    always begin
	#10
	clk=1;
	#10
	clk=0;
	#10
	clk=1'bx;
	#10
	clk=0;
	#10
	clk=1'bz;
    buffer buf0 (b, clk);
    resistor #(.r(100k)) r0 (b, gnd);
module buffer (out, in);
    output out;
    input in;
    assign out = in;
// Logic to Electrical Connect Module
// Version 1a, 1 June 04
// Olaf Zinke
// Downloaded from The Designer's Guide Community (www.designers-guide.org).
// Post any questions on www.designers-guide.org/Forum.
// Taken from "The Designer's Guide to Verilog-AMS" by Kundert & Zinke.
// Chapter 4, Listing 18.
connectmodule d2a (out, in);
    parameter real v0 = 0.0;			// output voltage for a logic 0 (V)
    parameter real v1 = 5.0;			// output voltage for a logic 1 (V)
    parameter real vx = 2.5;			// output voltage for a logic x (V)
    parameter real vz = 5.0;			// output voltage for a logic z (V)
    parameter real r0 = 1k from (0:inf);	// output resistance for a logic 0 (Ohms)
    parameter real r1 = 1k from (0:inf);	// output resistance for a logic 1 (Ohms)
    parameter real rx = 100 from (0:inf);	// output resistance for a logic x (Ohms)
    parameter real rz = 1M from (0:inf);	// output resistance for a logic z (Ohms)
    parameter real tr=1n from [0:inf);		// rise time (s)
    parameter real tf=1n from [0:inf);		// fall time (s)
    input in;
    output out;
    logic in;
    electrical out;
    real v, r;
    assign in = in;
    initial begin
	case(in)
	    1'b0: begin v = v0; r = r0; end
	    1'b1: begin v = v1; r = r1; end
	    1'bx: begin v = vx; r = rx; end
	    1'bz: begin v = vz; r = rz; end
	endcase
    always @in begin
	case(in)
	endcase
    analog
	V(out) <+ transition(v, 0, tr, tf) + transition(r, 0, tr, tf)*I(out);
