I see the following code on LRM. I do not see "mixedsignal" defined. Whether "mixedsignal" is a reserved word?
Could you explain it to me?
Code:module dig_inv(in, out);
input in;
output out;
reg out;
ddiscrete in, out;
always begin
out = #10 ~in;
module analog_inv(in, out);
input in;
output out;
electrical in, out;
parameter real vth = 2.5;
real outval;
analog begin
if (V(in) > vth)
outval = 0;
else
outval = 5 ;
V(out) <+ transition(outval);
module ring;
dig_inv d1 (n1, n2);
dig_inv d2 (n2, n3);
analog_inv a3 (n3, n1);
connectmodule elect_to_logic(el,cm);
input el;
output cm;
reg cm;
electrical el;
ddiscrete cm;
always
@(cross(V(el) - 2.5, 1))
cm = 1;
always
@(cross(V(el) - 2.5, -1))
cm = 0;
connectmodule logic_to_elect(cm,el);
input cm;
output el;
ddiscrete cm;
electrical el;
analog
V(el) <+ transition((cm == 1) ? 5.0 : 0.0);
connectrules mixedsignal;
connect elect_to_logic;
connect logic_to_elect;
endconnectrules
