Aug 17th, 2024, 11:22am
Why there is no sine wave after adding a digital module? (Read 2015 times)
ruwan2
Mar 31st, 2015, 8:10am
I am learning verilog-AMS. When I only use sine wave module sinVarFreq, there is a sine wave in the transient analysis. If I add a digital module, please see the full code in the following snippnet, there is no sine wave in transient window. What is missing if there are both digital and analog in a project?
.LIB "testbench.vams"
.lib "sine_source.vams"
.ELABORATE work.testbench
.ELABORATE work.sinVarFreq
.Trace  Tran   IN(M) Min=-1.0000000e+00 Max=3.0000000e+00
.Trace  Tran   src Min=-1.0000000e+00 Max=3.0000000e+00
xsine   src  src_n   sinVarFreq
xtest_bench testbench
`timescale 100ps / 1ps
`include "disciplines.vams"
module testbench ();
    electrical gnd;
    ground gnd;
    reg clk;
    initial clk=0;
    wire b;
    always begin
	#10
	clk=1;
	#10
	clk=0;
	#10
	clk=1'bx;
	#10
	clk=0;
	#10
	clk=1'bz;
    buffer buf0 (b, clk);
    resistor #(.r(100k)) r0 (b, gnd);
module buffer (out, in);
    output out;
    input in;
    assign out = in;
`include "constants.vams"
module sinVarFreq(p, n);
    inout	p, n;
    electrical p, n;
    parameter real freq  = 1.0e5;
    parameter real coeff = 1.0e-3;
    real tempr;
    analog begin
	  V(p,n) <+ sin(`M_TWO_PI * freq * $abstime * 80e2);
boulate
Re: Why there is no sine wave after adding a digital module?
Reply #1 - Apr 1st, 2015, 9:14pm
Your verilog-a source is floating, try to replace
by
xsine   src  0   sinVarFreq
