Nov 7th, 2026, 9:47pm
adexl conditional specifications (Read 2087 times)
danmc
Boston
Apr 03rd, 2015, 12:25pm
I'm having troubles writing conditional specifications in ADE-XL and am wondering if anyone has good suggestions.  Here is a simple example:
circuit:  tunable lowpass filter
simulation:  ac sim that measured -3 dB bandwidth
parameters:  frequency control, PVT
so what I want is to run a bunch of simulations over PVT and with the frequency control at min and at max.  My specs would be then:
BW_sim@control=min < minimum bandwidth spec
BW_sim@control=max > maximum bandwidth spec
In other words, the sim looks over PVT and makes sure the desired range of bandwidths is achievable over all PVT.
I don't know how to make the measurement in ADE-XL depend on the frequency control parameter.
-Dan
weber8722
Re: adexl conditional specifications
Reply #1 - Apr 21st, 2015, 10:34pm
I think two approaches are the simplest in ADEXL:
1. Use of variables like VGainSetting and use of VAR("VGainSetting") in the output equations. Run eg. an AC sweep at fix freq (like 100MHz) and sweep this variable. With value(VF(out) ...) you can pick the desired gain
or
2. Make just two tests: One for low-gain and a 2nd for high-gain.
Also corner-specific specs are possible using "spec-overridings".
Bye Stephan
