Nov 7th, 2026, 8:53pm
ADC DNL INL simulation using adc_dnl_8bit (Read 2036 times)
kane
HZ
Apr 15th, 2015, 7:07pm
I am designing SAR ADC and want to use "adc_dnl_8bit" block to get the DNL of the ADC. But I found the amplitude of the "vclk" is too small. 1.  how to solve this problem?  2. where to get the DNL value ?
weber8722
Re: ADC DNL INL simulation using adc_dnl_8bit
Reply #1 - Apr 21st, 2015, 10:36pm
isnt there a parameter to enter the clk amplitude? Use Edit Property, then swtich the cyclic field to "veriloga" to see all parameters.
If this is still a problem use e.g. an vcvs from analogLib as little amplitfier. This is also needed for differential circuits.
Bye Stephan
