danmc
Boston
I'm having troubles writing conditional specifications in ADE-XL and am wondering if anyone has good suggestions. Here is a simple example:
circuit: tunable lowpass filter simulation: ac sim that measured -3 dB bandwidth parameters: frequency control, PVT
so what I want is to run a bunch of simulations over PVT and with the frequency control at min and at max. My specs would be then:
BW_sim@control=min < minimum bandwidth spec BW_sim@control=max > maximum bandwidth spec
In other words, the sim looks over PVT and makes sure the desired range of bandwidths is achievable over all PVT.
I don't know how to make the measurement in ADE-XL depend on the frequency control parameter.
Thanks -Dan
