May 3rd, 2024, 12:07pm
Using components from Technology Library in verilog A module (Read 491 times)
king28
Apr 06th, 2015, 8:21am
Hello everyone,
I want to instantiate a NMOS transistor from my technology library inside a verilog AMS module. This is needed because I am trying to modify the characteristics of transistor externally using some other devices for which model does not exist. So I write IV characteristics in a file and use that in verilog A. Now I need to instantiate a NMOS transistor as well inside the verilog A module. How can I do that?
Re: Using components from Technology Library in verilog A module
Reply #1 - Apr 13th, 2015, 10:45am
The Verilog-AMS Language Reference Manual, Annex E Spice Compatibility, discusses instantiating Spice elements in a Verilog-AMS module.  Beyond that, you'd have to check with your simulator vendor to see if there is any special setting necessary for this to work -- how does the simulator resolve instances inside modules?  I've seen resistors inside modules, but I can't say I've ever seen an NMOS instantiated this way.
