ruwan2
Hi, I need to write a AMS code to synchronize a sine wave phase. That is, the code measure the value of a phase not known sine wave. After it measures for some periods of the sine wave, it outputs a pulse at the maximum sine magnitude. Of course, the accuracy depends on the sine wave SNR to the noise. Now, I only consider no noise case to make it simpler.
Because I am new to verilog-AMS, I would get help from you on beginning my work. Are there some functions helpful to the problem? What procedures and partition to the problem? This question is all from my personal interest. I can provide any info if you think that is required in the discussion.
