Aug 17th, 2024, 2:00pm
What function is available in a sine wave measurement? (Read 3101 times)
ruwan2
Apr 07th, 2015, 11:18pm
I need to write a AMS code to synchronize a sine wave phase. That is, the code measure the value of a phase not known sine wave. After it measures for some periods of the sine wave, it outputs a pulse at the maximum sine magnitude. Of course, the accuracy depends on the sine wave SNR to the noise. Now, I only consider no noise case to make it simpler.
Because I am new to verilog-AMS, I would get help from you on beginning my work. Are there some functions helpful to the problem? What procedures and partition to the problem? This question is all from my personal interest. I can provide any info if you think that is required in the discussion.
Re: What function is available in a sine wave measurement?
Reply #1 - Apr 8th, 2015, 10:28am
You probably want to take a look a the models on the Verilog-AMS page, particularly the period measurement models.
ruwan2
Reply #2 - Apr 15th, 2015, 7:04am
When I try to use the example code with period measurement, it is found that the EDA software does not support last_crossing() function. I would like to know whether there is a method to work around it. That is, to save the present crossing time for future use. In C language, there is a static variable can work. In verilog-AMS, is there a similar struct for this purpose?
Reply #3 - Apr 15th, 2015, 10:28am
Which simulator are you using? last_crossing is pretty simple functionality, I am surprised they would leave it out.
You can delete last_crossing() and just output the time of the crossing as measured by $abstime. However, it is less accurate. Alternatively, you can add code to do the linear interpolation yourself.
You should complain to your simulator vendor. They won't provide what you need unless you tell them what you need.
