Aug 26th, 2024, 3:17pm
High Voltage Adder (Read 2323 times)
bki
High Voltage Adder
Apr 10th, 2015, 2:59am
I like to sum three high DC voltages (50V each) up.
How can i sum those high voltages to 150V?
My advisor said that i can not do it by OpAmp adder circuit, because the OpAmp itself then needs a supply voltage of 150V which makes it useless?! It that really true?
newic
Re: High Voltage Adder
Reply #1 - Apr 14th, 2015, 7:43pm
use voltage charge pump... search for Dickson charge pump as a start.
