Jul 18th, 2024, 4:36am
variabe capacitor in hspice (Read 10496 times)
vahid
May 11th, 2015, 1:58pm
hi i decide simulate this circuit in hspice but i can't modeling variable capacitor section  the capacitors in this circuit change by move (capacitive accelerometer ) and Unfortunately i have no Enough information about veriloge  if I understand correctly , i can use veriloge in hspice
if you can write variable capacitor in verivlog i thank you verrrry much
Re: variabe capacitor in hspice
Reply #1 - May 12th, 2015, 10:40am
How do you plan to simulate the motion of the cap plates?
Verilog-A can support multi-physics simulations, where the position, velocity, and acceleration of the plates are unknowns of the system, and then the position is used to determine the capacitance.  I think you probably want to go this route, but if you don't know what I'm talking about, you have some reading to do before you're ready for the next step.
vahid
Reply #2 - May 12th, 2015, 11:38am
yes my goal is Use of capacitor plates movement to Calculate Acceleration in HSPICE
also acceleration type is transverse comb that you see on pic
my problem just write netlist for this section of circuit
Reply #3 - May 13th, 2015, 8:29am
I would probably write a Verilog-A model for the cap like:
 module varcap(t, b, x);
and then instantiate it in the netlist as
 xcap1 top bot xpos varcap ...
where "top" and "bot" are the electrical terminals, and "xpos" is a node that represents the position.  You'll want to be sure to scale xpos (perhaps simply choose appropriate units) so that the tolerances are appropriate (eg, if the plates move in nanometers, then when you represent xpos as a voltage with vntol=1u, you completely lose all accuracy).
I've put xpos in the netlist, so I can connect other elements to it; you could also try to put all the mechanical components inside the Verilog-A module.
vahid
Reply #4 - May 13th, 2015, 11:48am
thx for your answer
In order to simulate the transient response of the readout
circuit, a pair of time-varying sensor capacitors are required.
A simple varactor model is implemented in Verilog-A which
produces a voltage-controlled capacitor. This model has four
terminals, where two terminals are the capacitor terminals, and
the other are the voltage input terminals. The Verilog-A model
is built upon the following equation:
C = C0 + CV Vin (4)
Q = CVC (5)
IC = dQ/dt   (6)
This model consists of a fixed capacitor C0, and a variable
capacitor CV . The model takes in a voltage Vin as an input and
provides a variable capacitor C. Note that VC is the voltage
across the capacitor C. In this design, C0 is assumed to be
100 fF, CV is 1 fF, and Vin can be any time-varying voltage
signal that controls the change in the output capacitance.
now i can't write this verilog-a model
and i dont know vin must be sin voltage or not?
Reply #5 - May 15th, 2015, 11:48am
vahid
Reply #6 - May 15th, 2015, 2:39pm
yes but i dont know how define  and write  Vi and c=c0+c1vi  equation in veriloge and use it in hspice Embarrassed Embarrassed Embarrassed  :'( Cry
Reply #7 - May 18th, 2015, 7:14am
What is "veriloge" ?
vahid
Reply #8 - May 19th, 2015, 1:09am
excuse me  : verilog-a *
Reply #9 - May 19th, 2015, 11:09am
Step 1:
download the capacitor model; figure out the syntax to include it in your netlist, and run a simulation.
vahid
Reply #10 - Jun 13th, 2015, 2:08pm
hii i write this verilog-a for variable capacitor and i test circuit in hspice but capacitor don't change While i expected capacitance change sinusoidal please help me
`include "constants.vams"
`include "disciplines.vams"
module vccap(Cp, Cn, Vp, Vn);
   input Vp, Vn;
   inout Cp, Cn;
   electrical Cp, Cn, Vp, Vn;
   real C;
   parameter real C0 = 0;
   parameter real CS = 2.5p;
   analog begin
       C =  V(Vp,Vn);
       I(Cp,Cn) <+ C * ddt(V(Cp,Cn));
hspice test :
.hdl vccap.va
.options post=1
x1 1 2 3 4   vccap
vi 3 4 sin( 0 1 500k)
.tran 2n 500us
.PROBE tran cap(1,2) cap(1) cap(2)
.end
Reply #11 - Jun 14th, 2015, 11:34am
Two things:
  • The equations for a linear capacitor is: q=Cv and i=dq/dv, thus i=d(Cv)/dt. In other words, your C should be inside the ddt operator, not outside.
  • I suspect the probe statement is not working as you hope. I recommend you just do an AC analysis and measure your capacitance that way.
vahid
Reply #12 - Jun 14th, 2015, 12:59pm
Ken Kundert wrote on Jun 14th, 2015, 11:34am:
Two things:
thx Bro
rockypn
Reply #13 - Oct 29th, 2015, 3:11pm
I am trying to use PWL to get the curve for CV anyone has been successful in doing it ?
« Last Edit: Oct 30th, 2015, 11:35am by rockypn »
