Aug 26th, 2024, 3:18am
DRC ERROR: PSUB_STAMP ERROR MULT (Read 600 times)
sumangala
May 12th, 2015, 7:31am
i am working on DAC...i have created opamp layout with psub connected to vss and nwell conneted to vdd, there was no DRC and lvs error..... I have created switch layout with psub connected to gnd and nwell connected to vref, there was no drc and lvs error..... once i use this opamp and switch in DAC layout i am getting an error, PSUB_STAMP ERROR MULT...
Is this error because of connecting psub and nwell to different potential...??
philip_the_reverse
Re: DRC ERROR: PSUB_STAMP ERROR MULT
Reply #1 - May 14th, 2015, 12:18am
Forget about the nwell bulk for now, u might be getting the error because u placed two psub bulk on a single layer.
if you want to clean it
If u are using TSMC u will be having a layer in the LSW by name psub2 and place a rectangle around anyone block either switch or Opamp.
If u are using chrt u will be having a layer by name sxcut do the same as explained.
Check whether this works.
This psub2/sxcut isolates your vss from gnd or viceversa.
make sure all the vss/gnd nets come under the psub2/sxcut layer.
Reply back if it works.
If that works then the actual process is to place a dnwell, what ever explanation i gave u is used only for the cleaning LVS.
Hope this solves ur problem. Smiley
