Jeffrey987
Is there some kind of function in virtuoso layout where you can draw a polygon (where nothing else is inside) and get it filled with dummy metal?
Can be basic without too much tech file data.
like:
draw shape, set density, get filled, run DRC, manually remove some errors. Can be usefull in analog circuits where you do manual fill.
