Aug 14th, 2024, 8:15am
Dummy fill custom tool (Read 6581 times)
Jeffrey987
May 13th, 2015, 8:54am
Is there some kind of function in virtuoso layout where you can draw a polygon (where nothing else is inside) and get it filled with dummy metal?
Can be basic without too much tech file data.
like:
draw shape, set density, get filled, run DRC, manually remove some errors.
Can be usefull in analog circuits where you do manual fill.
A Kumar R
India
Re: Dummy fill custom tool
Reply #1 - May 20th, 2015, 2:17am
If not provided by the cadence, may be you can write a SKILL code.
