May 1st, 2024, 2:55pm
+mts in ams (Read 2700 times)
rajdeep
UK
+mts in ams
May 22nd, 2015, 9:47am
Hi Guys,
How can I netlist with a spice model in AMS?
The way I am doing this in spectre only is by adding this model to pspice model list and adding +mts in environment option. All this can be done via the ADE-L gui.
Now how do I do the same in AMS? I cannot find a place to add this +mts option, and when I try to netlist it is asking me to add this option. But where?
Rajdeep
AMS_ei
Re: +mts in ams
Reply #1 - Apr 18th, 2017, 9:55am
Hi Rajdeep,
I just saw this post now. I am not sure if you have got this answer.
There is a command called "runams" through which you can generate netlist from schematic.
runams -lib <library_name> -cell <cell_name> -view config -netlist -rundir top_run
This will create a netlist file called "netlist.vams" inside top_run directory.
Hope this helps.
Thank you.
Kind regards.
