Jul 22nd, 2024, 7:37pm
offset cancellation/correction circuit for opamps (Read 3956 times)
jovial
May 28th, 2015, 2:39am
Hello everyone,
I designed an opmap in schematic view in Cadence. It is giving no offset.
Then I did the layout for the same, and I get an offset of ~20mV between the differential output nodes.
Can anyone suggest me the way to do away with it? Or is there any circuit which when augmented with the present circuit cancels the offset.??
Any paper/book/reference is welcome...
Re: offset cancellation/correction circuit for opamps
Reply #1 - Jun 5th, 2015, 11:18am
research time IEEE JSSC and many of the analog CMOS textbooks will have material.
Also research transistor matching, common centroid differential pairs,
carlgrace
Berkeley, CA
Reply #2 - Jun 8th, 2015, 2:27pm
20 mV output-referred offset is pretty darn good for an opamp (unless you have really small gain).
Did you run monte carlo on the schematic before layout?  That will help you see how much of the offset is due to input pair mismatch.  Also, I'm guessing you designed a Miller opamp?  If you did than obviously you balanced the current density between the input and output current legs.  Since they will have slightly different Vds after layout that could also be the source of your offset.
If you really need to, you could center the design and maybe 1/2 the offset but most likely it is good enough.  Are you using the opamp in a negative feedback circuit?
Reply #3 - Jun 11th, 2015, 8:11am
20 mv is good for a CMOS op-amp
Bipolar can get to 1-3mV
chopper methods, alignment circuits etc are possibilities if needed
carlgrace
Berkeley, CA
Reply #4 - Jun 11th, 2015, 9:34am
loose-electron wrote on Jun 11th, 2015, 8:11am:
Very good point.  BJTs are off my radar... only ever used them in bandgap circuits.
Reply #5 - Jun 15th, 2015, 12:58pm
if you want low noise bipolar methods are still viable, but the foundry options are somewhat limited.
what you can get for noise performance from a large geometry NPN is pretty amazing, likewise matching, likewise transconductance
