Aug 15th, 2024, 7:07am
DE capsulation and RF Design Located Top Layer (Read 9727 times)
TurboV
Jun 01st, 2015, 10:31pm
Edited:
Hello. I'm not an electrical engineer nor do I have any RF background. Can anyone with RF background and experience with DE capsulation tell me once a decap is done on an IC (chip) is it possible to determine if the octagonal shaped structures represent a transmitter or a transceiver device ? This is under the assumption that the engineer examining the top layer of the die where the RF structures/design are located does not know anything about origins of the IC and from which system is it from ?
Lastly is it possible to perform a decap on a IC (plastic molded packages ) using a kitchen micro wave appliance ?
Re: DE capsulation and RF Design Located Top Layer
Reply #1 - Jun 2nd, 2015, 11:43am
nitric acid is used to decap plastic packaged parts.
there are companies that do reverse engineering of devices.
TurboV
Reply #2 - Jun 2nd, 2015, 4:17pm
loose-electron wrote on Jun 2nd, 2015, 11:43am:
Thank you for the reply. Would you know whether it is possible to perform a de cap using a kitchen household appliance on a IC which packaged using a plastic material ?
Reply #3 - Jun 5th, 2015, 11:22am
TurboV wrote on Jun 2nd, 2015, 4:17pm:
kitchen household appliance? Probably not. The nitric acid method is most commonly used.
wave
Reply #4 - Jun 5th, 2015, 2:06pm
Scarily enough there is a DIY way.
http://www.t4f.org/articles/ultra-low-cost-ic-decapsulation/
Still, I think I'd rather go down the street and pay a Pro $50 do it.
Wave Smiley
TurboV
Reply #5 - Jun 6th, 2015, 5:59pm
wave wrote on Jun 5th, 2015, 2:06pm:
Wave Smiley
Hello and thanks for the post. But can anyone else answer that once an IC has been de-capped and the top most layer examined under a microscope one can say the IC has a transceiver circuit design ? Another words the IC is capable of wireless communication.
aaron_do
Reply #6 - Jun 7th, 2015, 6:40pm
If you see a lot of spirals, then there's a good chance.
Reply #7 - Jun 9th, 2015, 1:37pm
Acid decap:
https://cdn.sparkfun.com/assets/7/a/6/9/c/51c0d009ce395feb33000000.jpg
mostly Logic and some analog:
http://i.stack.imgur.com/whWVa.jpg
All logic and memory banks
http://www.break-ic.com/microprocessor-read/images/atmega88c_sm.jpg
Mixed Signal ADC and DAC:
http://s.zeptobars.ru/MC33152-HD.jpg
Looking for a good example of an RF chip (with the usual inductors in the LNA, Mixer etc)
wave
Reply #8 - Jun 9th, 2015, 5:27pm
TurboV wrote on Jun 6th, 2015, 5:59pm:
I guess my thoughts and question is - what is the motivation of this question?
Is this a (crazy?) conspiracy theory that someone is spying on you?
Most systems have wired transceivers for USB, etc.
RF/Wireless transceivers are possible but not particularly practical unless the larger box is designed for such.
Any antenna in a chip would be very high frequency and/or lossy, so short range communications only.
For longer distance communication you'd need a Power Amp and good antenna someplace.  Those are very difficult to hide as auxiliary circuits in a system IC.
Huh
TurboV
Reply #9 - Jul 1st, 2015, 11:49pm
aaron_do wrote on Jun 7th, 2015, 6:40pm:
do you mean inductors ?
TurboV
Reply #10 - Jul 1st, 2015, 11:49pm
wave wrote on Jun 9th, 2015, 5:27pm:
Huh
Ah no that was the reason behind the post but thanks for the follow up
TurboV
Reply #11 - Jul 1st, 2015, 11:52pm
Would you know of any companies which are familiar with either one of the following:
1. Qualcomm Snapdragon IC design
2. Chinese "backdoor" RF IC
Would you recommend a company(s) which are experienced in reversing ? I already have Chipworks on this list. Would you know of any others ?
