TurboV wrote on Jun 6th, 2015, 5:59pm:Hello and thanks for the post. But can anyone else answer that once an IC has been de-capped and the top most layer examined under a microscope one can say the IC has a transceiver circuit design ? Another words the IC is capable of wireless communication.
I guess my thoughts and question is - what is the motivation of this question?
Is this a (crazy?) conspiracy theory that someone is spying on you?
Most systems have wired transceivers for USB, etc.
RF/Wireless transceivers are possible but not particularly practical unless the larger box is designed for such.
Any antenna in a chip would be very high frequency and/or lossy, so short range communications only.
For longer distance communication you'd need a Power Amp and good antenna someplace. Those are very difficult to hide as auxiliary circuits in a system IC.
