Aug 15th, 2024, 9:14pm
delta sigma modulator simulation (Read 277 times)
tul84
Jun 09th, 2015, 11:25am
Hello everyone,
i am trying to simulate the accuracy of a delta sigma modulator (first order). It is a fully-differential switched capacitor integrator with a latched comparator. Transient simulation works, the question is how to evaluate the bitstream to get the accuracy for a given DC input voltage. Is it possible to perform a PSS, PAC or Pnoise simulation of the modulator?
Thank you in advance.
RobG
Bozeman, MT
Re: delta sigma modulator simulation
Reply #1 - Jun 9th, 2015, 12:43pm
With a 1st order the decode is just a counter. For example, if you take 4096 samples and 100 of them are high, then your converted input is 100/4095*Vref.
tul84
Reply #2 - Jun 9th, 2015, 11:41pm
Thank you.
What have you used for counting matlab or a model directly in cadence.
Any idea concerning PSS, PAC or Pnoise simulation.
RobG
Bozeman, MT
Reply #3 - Jun 10th, 2015, 10:48pm
tul84 wrote on Jun 9th, 2015, 11:41pm:
Thank you.
Just normalize the bitstream to 0 and 1 and take the average using your favorite method, that will give you (counts high)/(total counts).
PSS can be used to get spectrums, not sure about DC values... it is on my list of things to learn.
tul84
Reply #4 - Jun 11th, 2015, 11:07pm
I have some experience with PSS, PAC and PSTB applied to fully-differential OTA's with SC-CMFB. I have also tried it now for the DS modulator but it did not converge.
For Simulation i have now written a Verilog-A model for counting the one's the bitstream for 2^N samples. Works fine, but is not satisfying in therms of simulation time and disk space.
Reply #5 - Jul 1st, 2015, 1:33am
Tul84,
  In general, PSS can't be applied to a delta sigma modulator because
their behavior is non-periodic. This is the same reason that you need
to use the Hann window function for the FFT instead of the rectangular
window, as you can do for a Nyquist rate ADC.
RobG
Bozeman, MT
Reply #6 - Jul 3rd, 2015, 8:40am
My partner uses PSS for continuous time DSMs. He models the comparator with an ideal unity gain buffer so there isn't any switching. I don't know if it would work with switched capacitor designs unless you did a continuous time equivalent. Additionally, I don't know how accurate his results are but they seem to be ballpark.
