That all depends on what the inverter will be driving. Many loads are not actually sensitive to noise much of the time. The noise analysis you do should reflect that. If it is driving another gate, then you should probably run some kind of jitter analysis because the gate is only sensitive to noise at threshold crossings and the most natural metric is as a variation in time.
As far as how to load the circuit you are measuring, you should add a load that models the stage that you will be driving.
