Jul 5th, 2025, 1:39pm
rgbi in Cadence noise simulaion (Read 4713 times)
Stridertang
Jun 09th, 2015, 11:17pm
When I do a noise simulation for an LNA, the noise summary shows a "rgbi" as noise parameter, and my question is what is this kind noise comes from? How can we reduce the rgbi noise ?
spectrallypure
Re: rgbi in Cadence noise simulaion
Reply #1 - Oct 4th, 2018, 6:30pm
Hi Stridertang! I've come across the same problem... did you ever find out what is this noise modelling? In my noise summary it's the dominant source of noise!
Reply #2 - Oct 5th, 2018, 6:44am
Perhaps it would help if you indicated what kind of device was producing this noise.
Reply #3 - Oct 21st, 2018, 11:07am
I expect this is:
rgbi: Gate Bias-Independent Resistor thermal noise
However, to be certain, knowing the device type would help, as Ken said.
Reply #4 - Oct 22nd, 2018, 6:20am
Speculating even further: I do recall an issue in BSIM4, version 4.5.0, where the noise for RGATEMOD=2 was incorrect; this was fixed in version 4.6.0. I've attached a screenshot from BSIM460_ReleaseNotes.pdf
This fix was made a while ago, but some foundries are still specifying version=4.5 in their model files.
