There should be a way to have Spectre tell you the noise contributions not only from each device but from each noise source within the device; eg, you should be able to see if it's the channel thermal noise, or the noise of the resistors (rd, rs, rg), or the flicker noise.
I also think you can turn off the noise of a specific device, something like is_noisy=no (perhaps as an instance parameter?).
