Hi Sheldon,
Thanks for your good calculation which guiding me well understood the phenomenon. The step is due to digital trimming algortith which drives a nonaccurate clock to a target one.
So the frequency jittering is due to accuracy setting, right? If i set maximum step 1ps, then the expected varaition is 10kHz, right?
Could you also please explain a little why the maximum step impact on the frequency solution of circuit?
Is there any ways to kill the "jitter" without affecting simulation speed?
Thanks very much.
sheldon wrote on Aug 13th, 2015, 10:26pm:hiSkill,
Do you mean the pulse or the small variations in frequency? For
the small variations, the accuracy is 10ps. Using my handy paper
napkin to help with the calculations. Adding ad subtracting 10ps
for the period at 72MHz, the expected variation is frequency is
about 100kHz[+/- 50kHz variation from the center frequency]
so the low level noise seems to be consistent with the numerical
accuracy control. Not sure what is causing the step.
