Sep 16th, 2026, 8:13am
Cadence IC5.1 and MMSIM10.1 (Read 1797 times)
Naga Kishan
Aug 19th, 2015, 11:32am
I am using Cadence IC5.1 with MMSIM10.1 and simulating for phase noise using PSS/Pnoise analysis.
The simulation runs well for PSS, but it shows 2 warnings as shown below for Pnoise:
1) Warning from spectre at freq = 100 MHz during PNoise analysis `pnoise'.
   WARNING (SPECTRE-16518): Arithmetic exception in analysis `pnoise' .
2) Warning from spectre at freq = 1 Hz during PNoise analysis `pnoise'.
   WARNING (SPCRTRF-15037): Infinite flicker noise is ignored.
I will be obliged for your help.
Naga
Naga Kishan
Re: Cadence IC5.1 and MMSIM10.1
Reply #1 - Aug 20th, 2015, 12:22pm
I am using the following specifications to calculate the CMOS ring oscillator (Inverter-5stage)
PSS
Engine: Shooting
Fundamental frequency 3.1GHz
Number of Harmonics 64
errpreset: moderate
tstab: 333ns
Oscillator . clk, gnd!
pnoise
sweeptype. relative
relative harmonic: 1
output frequency sweep range: 100K - 100MHz
sweep type: log
points per decade: 200
Maximum sidebands - 64
output - voltage - clk, gnd!
Noise type - sources
Noise separation - yes
I get the below attached phase noise value.
So, my main questions are:
1. Does this plot look reasonable?
2. what should be the phase noise value for a best ring oscillator (or in a range of dBc/Hz)
3. It is used for a divider circuit which CML logic which uses differential clocks ( clk and clkb ), so i designed with a inverter at the output of the oscillator. So, my question is does the phase noise differ for clk and clkbar (complement). does i need to use clkb for reference node in both pss as well as pnoise.
Thanks for your quick reply in advance.
