Jul 19th, 2024, 5:22pm
Pages: 1 2
Noise Simulation of Chopper Amplifier using PSS & Pnoise (Read 20452 times)
ULPAnalog
Re: Noise Simulation of Chopper Amplifier using PSS & Pnoise
Reply #15 - Mar 16th, 2016, 12:52pm
Hello Raghu
I looked at your schematic once again and recognized it is a single ended output structure. Is that correct? Also it is not clear which of the nodes is out? It looks to me as if 2 nodes are labelled out. Not sure if I am reading it right.
Raghu9685
Reply #16 - Mar 16th, 2016, 10:40pm
Hi ULPAnalog
Yes It is single ended output structure. both label are not same one are "out" and another one is "out-" . I tried both the cases first I given the single output of amp to anti-chopper circuit not getting result so I also tried that double ended output to anti-chopper circuit then also I am not getting result.
Thanks & Regards
Raghu
ULPAnalog
Reply #17 - Mar 17th, 2016, 7:54am
Hello
Could you post the resulting plots and key specs including the chopping frequency etc?
Raghu9685
Reply #18 - Mar 18th, 2016, 4:52am
hi
My Institute cadence license got expired it will take at least 10 days for renewing  so I will post the result as soon as I get license.
pandilla
Reply #19 - Aug 27th, 2017, 10:28am
what is circuit there inside the chopper box?
please explain anyone...
thanking you...
Pages: 1 2
