Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 18
th
, 2024, 10:38am
Home
Help
Search
Login
Register
PM to admin
Simulators
AMS Simulators
› ncelab DLWTLK error
Previous topic
Next topic
ncelab DLWTLK error (Read 2533 times)
nivani
ncelab DLWTLK error
Sep 08
th
, 2015, 5:11am
I am having a problem when running the AMS simulation and when there is a single transistor from the PDK in the testbench.
The error that pops up in the log is:
ncelab: *N,DLWTLK: Pausing until a shared lock can be established on library 'std'. Another process may be accessing the library. Process will resume when the lock is established.
Does anyone have any advice on how to solve this error?
I tried using the nchelp command to explain the error and one of the suggestions was to use ncpack -unlock std to manually terminate the process but I do not have the permission to do so.
IP Logged
Re: ncelab DLWTLK error
Reply #1 -
May 13
th
, 2016, 10:10am
Can you see the lock file? Is it owned by you? If so, you can try to delete it. If it's owned by someone else, ask that person to remove the file (or use "ps -ef" to find the process that established the lock).
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
»» AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
