Jul 18th, 2024, 2:34am
wreal: reaction to a signal change is not working properly (Read 4293 times)
Zorro
Sep 17th, 2015, 5:41am
Hi Community,
I am having a problem that I cannot understand.
This simulation uses wreal only.
I have 2 internal signals which should react to a variation in the signal iload.
If iload > value the response signal should be high, otherwise the response signal should be low.
Example 1 (working as expected)
I am varying iload in steps of 1m.
Let's say value=100m
If iload  is 100m or higher, then the response signal should be high
If iload is 99m or lower then the response signal should be low
-> this is working fine
The problem occurs if I use another "value", let's say value=50m
Example 2 (not working as expected)
Let's say value=50m
If iload  is 50m or higher, then the response signal should be high
If iload is 49m or lower then the response signal should be low
-> this is not working fine. When iload decreases the response signal should become low when iload=49m, but this is ocurring when iload=50m and this is not correct
This is the code that I am using:
     real        high_current_overload;
     real      low_current_overload;
     always @(iload) begin
           if (iload >= 100m) begin
                 high_current_overload = 1.0;
           end else begin
                 high_current_overload = 0.0;
           if (iload >= 50m) begin
                 low_current_overload = 1.0;
           end else begin
                 low_current_overload = 0.0;
See Picture 1.
Please any suggestion to understand what is causing this problem?
Thank you!
Zorro.
Zorro
Re: wreal: reaction to a signal change is not working properly
Reply #1 - Sep 17th, 2015, 5:41am
Picture 1.
boe
Reply #2 - Sep 17th, 2015, 8:57am
Zorro wrote on Sep 17th, 2015, 5:41am:
Hi Community,
Let's say value=50m
Accumulation of numerical errors. I am sure your code will behave as expected if you use 49.995m as threshold.
- B O E
Zorro
Reply #3 - Sep 17th, 2015, 10:59am
Hi boe,
thanks for your reply.
Your suggestions partly solves the problem. To understand it properly could you please tell me what you mean when you say "Accumulation of numerical errors" ???
If I use value=49.995m as you suggests it works fine, as expected. See Picture 2.
But the question is: how do I know when I need to subtract that small delta from my threshold value???
As an example, if I use value=60m it works fine, without needing to subtract any delta. See Picture 3.
Thank you.
Zorro.
Zorro
Reply #4 - Sep 17th, 2015, 11:00am
Picture 2.
Zorro
Reply #5 - Sep 17th, 2015, 11:00am
Picture 3.
boe
Reply #6 - Sep 21st, 2015, 2:16am
Zorro wrote on Sep 17th, 2015, 10:59am:
Hi boe,
Thank you.
Zorro.
Zorro,
the simulator (usually) uses a binary representation for numbers, and the binary representation of 1m is infinite. Therefore, numerical errors occur and propagate through your calculation.
You may want to try the following (pseudo-)code
sum = 0
for i = 1 to 10000
   sum = sum + 1m
   print i, ": ", sum - 0.001*i
- B O E
