Jul 18th, 2024, 2:20am
PLL loop filter issue for veriloga model simulation. (Read 2435 times)
Homer
Sep 17th, 2015, 10:19am
I'm trying to implement a veriloga model for my pll design to predict jitter. I copied the block models from Ken's paper and merged them into one PLL loop schematic. For the loop filter I just use ideal devices with reasonable resistance and capacitance value.  Please check the  schematic drawing.
But the simulation is weird. It seems the simulator removed these LPF devices. The vcoin voltage is Mega Volt once chpp output current. And I can't find the node between resistor and capacitor in the simulation result.
Homer
Re: PLL loop filter issue for veriloga model simulation.
Reply #1 - Sep 17th, 2015, 10:25am
Add the simulation result
Homer
Reply #2 - Sep 17th, 2015, 10:41am
Sorry. It's not simulator and model issue.
I put symbol before spectre in the view list. And the netlistor didn't create these device in the netlist.
